hi there,
how can I use this command ----hw.exe -s ??
Thanks very much for your prompt reply
I am not sure
How did you know that command?
I got from this command as below:
C:\Program Files\Altair\14.0\hw\bin\win64\hw.exe -h
the help shows hw.exe -s can modify the size of the application,but I don't know how to use it.......
With -s option, you can start HyperWorks with the window of the specified dimension and location. For example, you can run hw.exe as following:
hw.exe -s 800x600+0+0
