Hello
I have constructed 16 elements C-Band phased array. Attached its design.
The design for all 16 elements is the same.
For some reason when I steer the array to some direction (attached POSTFEKO file for example), the VSWR results for each elements are different and vary too much, as can be observed.
What can be the reason for VSWR results difference between the elements.
Thanks in advance.
