Hello Team,
I am unable to load session file in hyperview 2021.2. It is created in same version but on other system. I am getting following error .
Can anyone please help me out regarding this.
"This Result Math Template is designed to be used for advanced use-cases and for full functionality requires a certain set of data types which are not available in provided files "
Thank you.
Can you make sure you have the correct files in the correct path/location as what is in your session file?
