Code are as follows, what causes the error?
Hi Qin
In your header file, you are including IPluginParticleBodyForceV3_3_0.h, but in your cpp file for the GETEFINTERFACEVERSION, although your INTERFACE_VERSION_MAJOR is 3, your INTERFACE_VERSION_MINOR is 4, which is inconsistent with the included header.
You can change the header file to include IPluginParticleBodyForceV3_4_0.h, or change the INTERFACE_VERSION_MINOR to 3.
Hope this helps.
Thanks,Jerrin Job
It finally worked, thank you for your help.
I'm looking forward for Altair to have better document, so that programmer can use API smoothly.
Qin
