Is there any possible way to set up the model, so that i can get individual h3d file for individual subcases (load step).
Surya Koneti
Hi Surya,
There are options available to obtain individual h3d files for each subcase (load step). Please find the option below.
You can create an OUTPUT CARD and define the keywords as shown in the image.
Sriramanuj Prabhu.
Thanks, Sriramanuj for your suggestion.
Kindly designate the solution as correct to enable others to make use of this option as well.
Thanks.
These outputs are created at-once, after the completion of all the subcases present at the end. Is it feasible to obtain a certain outcome as soon as the corresponding subcase convergence?
Thanks & Regards,
Hello, These outputs are created at-once, after the completion of all the subcases present at the end. Is it feasible to obtain a certain outcome as soon as the corresponding subcase convergence? Thanks & Regards, Surya Koneti
You can make use of the NLMON option as below.
