Hello all,
I would like to shoot water particles at a tube filled with particles. For this purpose, small holes are embedded in the nozzle geometry where the factories are positioned. The holes/factories have a defined angle from which the particles should come out with a certain velocity. When the nozzle starts to rotate, the angle remains fixed and does not rotate with the nozzle. Is there a possibility to let the angle rotate with the nozzle ?
In the picture you can see the rotation of the nozzle and the coordinate system of the factory. The particles should be generated along the Z-axis and start rotating when the nozzle does.
Thank you in advance
