Could you tell me the .tcl command to export a table in .ses format ( patran)?!
i can't find it anywhere. Thank you
I am not familiar with .ses format but , assuming you are exporting from HyperMesh, when you do it manually what commands show in the command_#.tcl file?
no one otherwise I didn't ask questions ????
Please tell me the process you use to do it manually.
2) tools -> set browser -> export set ( .session file )
perhaps the right question was: how to export a table in “.ses” format with .Tcl commands
1) create Elm set2) tools -> set browser -> export set ( .session file ) perhaps the right question was: how to export a table in “.ses” format with .Tcl commands
1) create Elm set
Looks like it doesn't exist. I will request it and see if there is a workaround.
the solution exists to export table in format separated by a symbol of your choice. it seems too strange to me that there is no solution for export in .ses Patran format. if you can find anything i am grateful
There is a tcl command to export table? Please share.
I have requested that a hm api be created to export a .ses file. So, hopefully, in the future you will be able to do this with one command. Otherwise you can certainly write a file with tcl in whatever format you want. It just may be a little tedious. The basic commands will still be open, puts and close. Each new puts would add another line to the file. Something like this:
*createmarkpanel sets 1set setList [hm_getmark sets 1]set fp [open $outFile w];puts $fp "\$# Started creation of session file $outFile at 10-Mar-23 14:03:05"puts $fp "\$# Exported by: Altair HyperMesh 2022.2.0.27"puts $fp "sys_poll_option( 2 )"foreach set $setList { set setName [hm_getvalue set id=$set dataname=name] puts $fp "ga_group_create( \"$setName\" )" puts $fp "ga_group_entity_add( \"$setName\", \" Element [hm_getvalue set id=$set dataname=elementids]\" )" puts $fp "sys_poll_option( 0 )"}puts $fp "\$# Stopped creation of session file exportSimple.ses at 10-Mar-23 14:12:33"close $fp
You will need to set the outFile variable with the output file and if your set is very long will need to create line breaks but this is the basic idea.
The ExportToSession procedure in the default_component.tcl looks like it does what you want.It is in the installation directory \hwdesktop\hm\scripts\browser.
Hey Giovanni,
just stumbling into this conversation and wondering what is missing from the HyperWorks package which leads you to the need of workign with Patran session file
Let me know and hopefully we can provide a was better shortcut to your workflow.
Ciao
Michele
Hey Giovanni, just stumbling into this conversation and wondering what is missing from the HyperWorks package which leads you to the need of workign with Patran session file Let me know and hopefully we can provide a was better shortcut to your workflow. Ciao Michele
The demand is the result of work necessities that still impose an old way of working based, pardon the repetition, on other software.
