Is possible write e script in HM to export a table in .ses file format
Hello Giovanni,
if .ses is an ascii format, for sure you can use tcl for writing it. Then it depends if the format is free or fixed. If you have to respect a given format, then you need to format your command accordingly.
Below are the regular commands we recommend for writing into an ASCII file:
Command
Effect
set fIn [open $file w]
Open the file to overwrite it
set fIn [open $file a]
Open the file to write it in append mode
puts $fIn $string
Writes the string in the file
close $fIn
Close the file
format %format $string
Force the format for a given string
For the format command, here is an example of use:
