given a node, it is possible to obtain the list of elements connected to this node through Matrix. i'll explain better. when using the “ Fastener setup” in Aerospace matrix, you can usually create a dove report that defines Bush IDs and elements connected to the end fi nodes ( 2D elements connected to RBE3 tramide). orw I would like to get something like this Matrix tranite once the cbush was created. data then a list of Cbush get a list of 2d elements connected at the end. Thank you
