Hello. I need to mesh one part, but due to its small size, the quality of the mesh is poor. What is the solution to increase the mesh quality? The relevant parts are clear in the photo .
For the top image, if that feature is critical there is not much you can do, since the geometry is controlling the mesh quality in this case. Otherwise you can try suppressing some of the lines to see what mesh you get then. Probably not the best option but you could manual move nodes to get the quality you want.
For the bottom image it is not clear to me what to do but, if it is a fillet, look into using mesh controls.
https://help.altair.com/hwdesktop/hwx/topics/pre_processing/meshing/mesh_controls_type_surface_meshing_r.htm?zoom_highlight=mesh+controls
