I am having this error when running a modal analysis
*** ERROR # 2985 ***
Dependent DOF 1 of GRID 1035 cannot be converted to an
independent DOF with AUTOMSET for this rigid configuration.
There are not enough constraint equations to reformulate it.
If RBODY is used in the model, it is getting overconstraint in the model.
By adding "DEBUG,REMOVRGD,1.", Optistruct would not create constraint
on the dependend node of RBODY.
*** Run terminated because of error(s) in the input data.
I would like to know how resolve it, but I do not know the way to add "DEBUG,REMOVRGD,1." that it is suggesting
Is there there a specific way to do so ?
Thanks
