Hello. I need to mesh one part, but due to its small size, the quality of the mesh is poor. What is the solution to increase the mesh quality?The relevant parts are clear in the photo.
First you should check the quality of your geometry (small features for examples) and correct them.
You can also use the Rebuil tool which is based on param and criteria files where your elements criterias are defined.
Marine Racollet
