I am having some trouble comparing the results that are displayed in POSTFEKO and the results in the .out file. I made a script that imports the far field values in MATLAB and when I use these complex field values (in Volts according to the .out file) and calculate the RCS in dBsm the values are different than the results I get in POSTFEKO, which look correct. The equation I'm using for dBsm is 20*log10(abs(E_theta)) (for example). Is this the same equation that is used in POSTFEKO? Thanks!
-Spencer
