Hi, I have a solid model which I imported in HyperMesh to do a linear static analysis. The solid is divided in two solids which I tried to merge but the SW says that they don't share any surface. I attach below the pictures of these two solids and their surfaces I thought were coincident. How can I make this two surfaces coincident in the way the two solids share the same surface?
