How to not have numbers convert to Scientific Notation when inserted into DB by Automator
User: "Leonid"
New Altair Community Member
Updated by Leonid
In DPS is there a way to make sure that numbers that are displayed normally don't get converted to scientific notation when inserted into a database by Automator. Currently, the only way I found is to convert them to Text, which is not desirable.
#Automator #DPS #scientificnotation
Leonid Shteyngardt
App Development Manager
Canaccord Genuity Inc.
New York NY
(212) 389-8176
1 - 3 of 31
    User: "Mo Abdolrahim"
    Updated by Mo Abdolrahim
    Hi Leonid,
    You can create the table schema in the SQL database table and configure columns (fields) based on their types.
    For example, numeric integer fields to Int, or Numeric decimal fields to Float.
    In the Automator Visual Process in Data Prep Export you can manually map each workspace table field to a table field in SQL.
    Regards
    Mo
    Mahmoud Abdolrahim
    Senior Implementation & Integration Engineer
    Altair Engineering
    Original Message:
    Sent: 12-03-2020 11:27 AM
    Subject: How to not have numbers convert to Scientific Notation when inserted into DB by Automator
    Leonid Shteyngardt
    New York NY
    (212) 389-8176
    User: "Leonid"
    OP
    Updated by Leonid
    Hi Mo,
    We'd like to keep all columns in the tables that we load from Monarch as varchar, in case the input data is not perfect - alpha characters in numeric or date fields, etc. This way we at least load the data and then deal with cleanup in stored procedures.
    So, although DPS displays the large numbers correctly as they are in the PDF file - all digits visible, when we run the process in Automator,  it converts large (or small) numbers into scientific notation and thus losing information - 123456789 gets converted into 1E+8. To avoid this, we have to convert each field into Character - either in the Report Design or later in the table.
    It would be helpful if Monarch would not implicitly convert numbers to scientific notation when inserting into varchar columns.
    Thank you,
    Leonid
    The information contained in this communication may be confidential and/or legally privileged. If you are not the intended recipient, please contact the sender and destroy all copies of this message and any attachments. Any disclosure, copying, distribution or taking any action in reliance on this information other than by the intended recipient is strictly prohibited and may be unlawful. Canaccord Genuity LLC is required by regulation to review and store both outgoing and incoming electronic correspondence. E-mail transmissions cannot be guaranteed to be secure, timely or error-free. This communication is not an offer or solicitation to buy or sell any security or other investment product. Additional information, including disclosures regarding securities under research coverage, is available at http://www.canaccordgenuity.com/en/Our-Company/Research/. Any information regarding specific investment products is subject to change without notice. Canaccord Genuity LLC - Member FINRA/SIPC.
    Original Message:
    Sent: 12/3/2020 11:28:00 AM
    Leonid Shteyngardt
    New York NY
    (212) 389-8176
    User: "Phil_20586"
    Updated by Phil_20586
    Hi Leonid,
    Regards
    Mo
    Mahmoud Abdolrahim
    Altair Engineering
    Original Message:
    Leonid Shteyngardt
    New York NY
    (212) 389-8176
    Leonid,
                  For financial values (for example) as Mo said I use the decimal feature when writing to the database.  However, if you read that DB field back into DPS and then perform add/sum/difference functions I have experienced where fractional parts of a penny still result from calculation reading in DB fields that had more decimal precision.  The two methods I have used to overcome this are: a) convert to text and then back to a number in DPS or b) use the round function within mathematical arguments.
    Phil Magrogan
    Immersion - SDVOSB
    Original Message:
    Sent: 12/3/2020 11:48:00 AM
    Subject: RE: How to not have numbers convert to Scientific Notation when inserted into DB by Automator
    Hi Leonid,
    Regards
    Mo
    Mahmoud Abdolrahim
    Altair Engineering
    Original Message:
    Leonid Shteyngardt
    New York NY
    (212) 389-8176
