I have a compound filter that identifies and shows me duplicates between two lists of data.
I want to remove those found duplicates from another compound filter.
Is this possible? Is there an easier way to do this?
In other words I only want the duplicated lines to show on one of the two compound filters I have.
EDIT: Here is the compound filter that I want to remove the duplicates from if that helps.
