Edge port load parallel capacitor
In the attached CADFEKO model I have defined a edge port connecting a gap in a defected ground plane. For the port 3 I defined a load with a parallel capacitor. The computed S-parameter is shown below, where it can be observed that the values are larger than which is not correct.
Can you please have a look at the model and let me know how to define a SMD capacitor at the gap in the ground plane.
Further, the computation time is significantly longer. Can you suggest a different solver in FEKO which is better suited for this model?
-> I think the SMD capacitor should be connected using serial connection (instead of parallel.).
(I don't know how to locate the cap parallelly between the gap.)
-> Normally, FEM solver is better for the planar structure. In addition, I'd like to recommend you to use "Planar multilayer substrate" as below.
Jaehoon
