In the attached editfeko file I would like to change the material property of a defined wire antenna from PEC to Copper. I added the following lines after the EG card.
DI: copper : -1 : 3 : : : : 1 : 58130000 : 0
ME: copper
When I open the postfeko file after running the simulation the wire antenna is still defined as PEC. Can you please have a look at the attached .pre file and let me know how to assign the material correctly.
