I am working on a coreless single stator double-rotor machine Axial Flux Machine. When i change the number of pole pairs from the geometrical parameter, it fails to reflect on my 3D geometry.
Case 1: Pair poles to 10
Case 2: Pair poles to 8
How do i solve this?
Hi Isiaka,
I think there is an issue in the way you parameterized your AFM model. If I can see the model, I can propose a solution.
Can you share your email connected to your Altair one account?
I will create a ticket where you can share your model.
Thank you,
Lavanya
Already created a case via isiaka_22000514@utp.edu.my
