I JUST DESIGN A DUAL ROTOR WITH CORELESS STATOR. However, my object geometric operation and entities changes to convert. How do i rectify this to enjoy remodification
Hi Isiaka,
Thank you for contacting us.
As an initial answer, I can suggest you to separate the volumes (you want to modify) from the existing object. Then you edit it or do any geometry operation.
To separate the volumes, you can use the option "Correction&Simplication >> Separate volumes >> New >> Select the volumes you want to modify".
But to suggest you better, I would request you to raise a support case and upload the Flux model.
Thanks
Karun
