I GENERATED A SAMPLE OF RESULT FOR A MODEL AND NEEDED THE png or jpg format. How will i do it
Hi Isiaka,
Thank you for contacting us.
After solving the model, you can plot the curves with help of Curves>>2D curve. Then you can a macro "AUTOMATICREPORT.pfm", then it will generate the result folder in the same directory where the model is saved in the form of ".png" format.
Thanks
Karun
Thank you Karun
