MY DESIGN IS CORELESS AND REQUIRES NON-SLOT, I HAVE DIFFICULTY IN REMOVING THE SLOT FROM THE MACRO AFIR.
HOWEVER IN BUILDING MY GEOMETRY, PERFORMING CIRCULAR REPETITION IN 3D, I HAVE ISSUE WITH THE ROTATION AXIS
Can you share the mdoel you use?
When you ty to delete the solts , in the model, you get an error message?
Thanks.
ok, i will share soon.
Find the attached for a single stator double rotors design. I will appreciate your kind assistance
Additionally, my target is to implement full-machine model like this
Hi, Can you share the mdoel you use? When you ty to delete the solts , in the model, you get an error message? Thanks.
Updated version.
You can check it out sir/ma
thanks I will check and keep you in touch
Okay, Thanks
Solved
