I am trying to model a coreless Axial Flux motor in flux for a twin-rotor single stator. The tutorials from macro or overlays is not sufficient. I need a proper guide or sample.
pls help
You are right. When you use AFIR macro you will get one rotor and one stator. But there is a way to create your model using the initial one you get from AFRI macro. Once the device is created using AFRI macro, you can use symmetry function from the modeler to create the second rotor.
Hope this will help.
Thanks.
