Hi @JIF !
I am trying to get electric field strength graph w.r.t to distance between two dipole antennas i.e how electric field varies from antenna 1 to antenna 2 while sweeping the distance .
For this I have requested near field pattern . While doing that I could see ' Error 17413: .\shared_helper.lua:108: An error occured while creating the models.' , which Iam unable to trace .
My distance is from 1*lambda to 1e5*lambda .
Could you help me in debugging the error ?
