ERROR 2331: Two triangular surface patches overlap
I am getting this error, but then when I go back a check for intersecting triangles. It is telling me that none are present in the model.
I also checked the .out file. It has the errors listed but no further info.
Everything in the model is unioned.
Part of the model is imported geometry. How do I fix this. When I run without the imported geometry included, it runs fine.
