Hello !
I am attaching some stiffeners to a tank (Img a). I'll leave images attached to better explain the problem.
I made sure that the stiffeners' mesh is coincident with the tank's mesh. Then, I copied the surface and element so I have the four stiffeners I need.
When I select the elements and I click on 'preview equiv', HM selects also all the nodes on some of the stiffeners (Img b). If I carry out the equivalence anyway the free edges on these elements disappear (Img c).
Do you know why is HM doing this ?
I have tried varying the tolerance but it did not change anything. I do not also understand why it only happens in the external stiffeners and not in all of them.
Thanks in advance !
Cordially,
EC
