 I'm developing a composite model for the rotor blade analysis, where I import the Catia-designed geometry into HyperWorks using Simulayt. Within this model, the plies are realized separately in the top and bottom halves of the geometry, with layers stacked inside from the tooling geometry. While the leading edge (LE) exhibits geometry connectivity, there's a narrow gap at the trailing edge (TE). The plies are intended to close this gap as they stack the layers. However, when applying loads to the model, I notice that the trailing edge near the loading becomes separated. So my question is: does the ply contact between the two halves imply they are effectively glued together, similar to the production process? Or should additional measures be taken to accurately ensure the contacts simulate the gluing process?
 Any suggestions are highly appreciated.
 Regards
 Ananthan
