Dear Support Team
I designed a PMSM in Flux and I performed some no-load analyzes like cogging torque and Back EMF calculation. Now I want to extract torque waveform by applying current source (instead of voltage source) and imposed speed. How can I do this? What circuit should be used? How is the optimal control angle calculated? Is any d-q transform required?
I would be grateful if you could help me with this, thank you.
