Error Running edempy
Fatemeh Hosseini_22198
Fatemeh Hosseini_22198 Altair Community Member
edited January 2024 in Community Q&A
Hello everyone,
I encountered an error while running edempy. Below is the error message:
<em>runfile('C:/Users/fatemeh.hosseini/Desktop/Fatemeh/Sensetivity analysis/spatial algorithm_agglomeration_newest.py', wdir='C:/Users/fatemeh.hosseini/Desktop/Fatemeh/Sensetivity analysis') WARNING: File "12mm-tube-partial_result.dem" was not created using a compatible version of EDEM. Please check edempy and EDEM are up to date.</em>
<em> Unexpected behaviour may occur. This warning can be disabled by setting the optional disableWarnings argument to True in the Deck constructor. e.g. Deck(deckname, disableWarnings=True)</em>
<em> WARNING: File "12mm-tube-partial_result_data/0.h5" was not created using a compatible version of EDEM. </em>
<em>Please check edempy and EDEM are up to date. </em>
<em>Unexpected behaviour may occur. </em>
<em>This warning can be disabled by setting the optional disableWarnings argument to True in the Deck constructor. e.g. Deck(deckname, disableWarnings=True)</em>
Could someone please assist me in resolving this issue?
Fatemeh
Welcome!
  • Renan
    Renan
    edited January 2024
    Hi Fatemeh,
    As the message says, this is not an error, it's just a warning. The message suggests that the EDEMpy version you're using is different than the version of EDEM you used to run your simulation. It's recommended that you use the same version of EDEM and EDEMpy to run and post process your simulation, respectively.
    Since there's no error, there's nothing to be done. If you want to disable the error message you can do so by using the disableWarnings flag when you define the deck in your code, e.g deck = Deck(deckname, disableWarnings=True)
    Best regards,
    Renan
  • Fatemeh Hosseini_22198
    edited January 2024
    Hi Fatemeh,
    Best regards,
    Renan
    Dear Renan,
    Thank you for your quick response.
    Apologies for the oversight in my previous message. I failed to include the complete error message. Following the warnings, the error I received is as follows:
    <em>Unexpected behaviour may occur. This warning can be disabled by setting the optional disableWarnings argument to True in the Deck constructor. e.g. Deck(deckname, disableWarnings=True)</em>
    <em>WARNING: File "12mm-tube-partial_result_data/0.h5" was not created using a compatible version of EDEM.</em>
    <em>Please check edempy and EDEM are up to date.</em>
    <em>Unexpected behaviour may occur.</em>
    Traceback (most recent call last): File ~\Desktop\Fatemeh\Sensetivity analysis\spatial algorithm_agglomeration_newest.py:49 in <module> Pos_contact_X=my_simulation_deck.timestep[t].contact.surfSurf.getXPositions()
    File C:\ProgramData\Anaconda3\lib\site-packages\edempy\timestep\SingleContact.py:193 in getXPositions return self.getPositions()[:,0]
    File C:\ProgramData\Anaconda3\lib\site-packages\edempy\timestep\SingleContact.py:188 in getPositions return self.getProperty('position')
    File C:\ProgramData\Anaconda3\lib\site-packages\edempy\timestep\SingleContact.py:93 in getProperty result = f[self.__contactPath + '/'+ option + '/'][:]
    File h5py\_objects.pyx:54 in h5py._objects.with_phil.wrapper File h5py\_objects.pyx:55 in h5py._objects.with_phil.wrapper
    File C:\ProgramData\Anaconda3\lib\site-packages\h5py\_hl\group.py:305 in __getitem__ oid = h5o.open(self.id, self._e(name), lapl=self._lapl)
    File h5py\_objects.pyx:55 in h5py._objects.with_phil.wrapper File h5py\h5o.pyx:190 in h5py.h5o.open
    KeyError: 'Unable to open object (component not found)'
    Fatemeh
  • Renan
    Renan
    edited January 2024
    Dear Renan,
    Fatemeh
    Hi Fatemeh,
    This kind of error usually means that there are no contacts in a particular timestep. You can wrap that part of your code in a try-except block to prevent that error from stopping your code. It would look something like this:
    try:    Pos_contact_X=my_simulation_deck.timestep[t].contact.surfSurf.getXPositions() except KeyError as error:     print("No pp contacts were found")
    Best regards,
    Renan
Welcome!
Welcome!
