what causes an agglomerate to fragment?
Hello everyone,
In the CFD-DEM simulation, I had a big agglomerate containing 900 primary particles.
During the simulation, it breaks into two different agglomerates with 400 and 500 primary particles.
I know turbulence shear or colliding with other agglomerates/geometry may cause this fragmentation but I couldn't find any criteria in EDEM documents or help.
Does it depend on impact velocity or kinetic energy of collision?
if yes, where can I find these equations or formulas in EDEM documents?
Fatemeh
Hi Fatemeh,
Particles in the agglomerate will separate if the forces trying to separate them are greater than the forces keeping them together.
The forces that separate particles could result from collisions and fluid drag forces among others.
The forces keeping particles together depend on the contact model and could be van der Waals type forces (JKR model, EEPA model) and solid bridge forces (bond model) among others.The magnitude of these forces depends on the respective model parameters (surface energy for JKR model, surface energy and pull-off force for EEPA model and bond critical shear and normal stress for the bond model). You could generally have anything from weak and brittle agglomerates to complete;y unbreakable agglomerates depending on the contact model and its parameters.
JKR model: https://help.altair.com/edem/Creator/Physics/Base_Models/Hertz-Mindlin_with_JKR.htm
EEPA model: https://help.altair.com/edem/Creator/Physics/Base_Models/Edinburgh_Elasto-Plastic_Adhesion_Model_(EEPA).htm
Bond model: https://help.altair.com/edem/Creator/Physics/Additional_Models/Bonding_V2.htm
Best regards,
Stefan
0 -
Stefan Pantaleev_21979 said:
Hi Fatemeh,
Best regards,
Stefan
Hi Stefan,
Many thanks for your answer.
I used JKR for the contact model and I see breakage of large agglomerates in the simulation.
I need equations about this process(sth like the balance between forces that you mentioned) for my article but I couldn't find anything in EDEM help.
Is there any section about agglomeration and fragmentation in EDEM documents?
Fatemeh0 -
Fatemeh Hosseini_22198 said:
Hi Stefan,
FatemehHi Fatemeh,
Please see the equations for JKR v2 model in the EDEM documentation:
The particles will separate when the forces pulling the particles apart exceed F_nc
For further details please see:
Thornton C. (2015) Granular Dynamics, Contact Mechanics and Particle System Simulations: A DEM Study. Vol. 24. Springer.
Best regards,
Stefan
1
