Hello everybody,
I should compare 2 different simulations (EDEM-Fluent coupling) simulation.
when I plot Coupling force versus time, 2 diagram behave totally different. the trend is same but the numbers are totally different.
and when I plot total force based on the time 2 diagram are approximately similar.
I need to know what is the difference between total force and coupling force exactly.
I insert:
lift, drag, virtual mass, gravity, and pressure gradient as an hydrodynamic force and HM-JKR as a contact force.
Can I say the only difference between these 2 forces in EDEM analyst graph is HM-JKR force?
Fatemeh
