Hello every one,
I am working on CFD-DEM (Particles in the tube) simulations by coupling EDEM and Fluent. I want to do scale up the system to reduce the time of simulation.
I used Archimedes, Froud, Reynolds, Cohesion numbers, and Volume fraction for scale up. (Because I want to scale up both CFD and DEM)
To make these dimensionless numbers constant I changed gravity, viscosity, particle diameter, surface energy, shear modulus, fluid velocity and tube size.
I want to know in this situation should I enter scale up factor in EDEM-Fluent interface or not?
Honestly, I believe that I should enter Scale up factor when I change only particle radius and now because I change different parameters I shouldn't enter this number. but I am not sure about this !
Could you please guide me?
Fatemeh
