Hi
Is it possible to get an estimate of the total weight of a structure modelled in feko which consists of metallic and dielectric materials? Also, is it possible to assign different metals for 'region' properties of a component?
Thanks
Vishakha
Hi Vishakha,
the surface area of all triangle elements and the volume of all tetrahedra is writen in the out-file. This may help to compute the weight of the structure.
You can assign different metals (with finite conductivity) only to faces and not to regions.
Regards
Christoph
