Selection of node
Dear sir/mam,
I created one script which can selects one node and renumber it.But now what problem i am facing is when i am running my script first time it is working fine and i can select node by using left mouse click.But, if i am using same script second time (Note: I am creating new session) it is not picking node by mouse click but it is picking one node always automatically if i left click on screen anywhere but not picking correct node (Note: If i select node by id option it is able to pick entered node id with that automatically picked node).If i close Hypermesh and opens again it is working fine for first time but, again from second time i am facing same issue.
Please help me as soon as possible. Thanks in advance.
Thanks and regards.
Vikas Kumar
Some screenshots or HM model to better understand your problem?
0 -
You can run this tool first time it will work fine second time just create new session and again run same .tcl script you will come to know the problem (Second time you will find not able to select node by left mouse click actually it won't work for any operation).
Note: before running the tool import any model in nastran profile i am using HM version 13.0.
0 -
You can find attached ppt file video for better reference.
0 -
More than 200 lines of Tcl code for just selecting some nodes???
0 -
/emoticons/default_biggrin.png' srcset='/emoticons/biggrin@2x.png 2x' title=':D' width='20' /> maybe the nodes are 200 tons weight!
0 -
I solved problem thanks for reply..
