Hello sir,
I worked on post-processing results and I am not getting the multiplier unit value....Multiplication is necessary to get the desired results....So kindly help me to solve this problem...
Thanks and regards,
Mahantesh.
Hi Mahantesh
Did you mean to apply the multiplier value to the legend?
If yes, you can set the value from edit legend option in contour panel.
Thanks
Thank U
