Connectors Bolts Failed!!
Hi to everyone,
i'm an aerospace engineer and this is my first time i write in this forum. I'm a Cad designer and I'm studing Hypermesh modeling. I followed several online courses and now I encountered a problem using bolt connectors. I have two solid parts, one partially inside another (see Img 1)<?xml version="1.0" encoding="UTF-8"?>
These parts are connected using bolts, and I want to simulate these connections using bolt connectors in hypermesh. The problem is that it's possible to use bolt connector (bolt washer 1 cbar with steel properties) in some holes (Img 1, yellow RBe2 and cbar elements), instead in other holes this is not possible. The connector become red and a message appears on connector panel (see Img 2)
'2 holes are required. Check diameter limits and tolerance or too close neighbor bolts'/emoticons/default_huh.png' title=':huh:' />
Wat does it means? What is the problem encountered?
Thank you very much./emoticons/default_smile.png' srcset='/emoticons/smile@2x.png 2x' title=':)' width='20' />
Can you increase the tolerance and check if this solves your problem?
If not, share the .fem file of the region where you are facing the issue
0 -
Thank you for the quick reply. I've tried to increase the tolerance (my hole's diameter is 5mm and i setted tolerance to 7) but nothng is changed. Here attached th .fem file. Thank you very much.
0 -
Hi Prakash,
did you manage to open the file??
Thank you
