How to create automatic weld between components in hypermesh? What is the procedure for creating seam and spot weld in hypermesh? How does it vary compared to general ruled meshing between components?
Hi Aditya,
You can create seam and spot weld through connector panel.
Please go through the below video link for detailed explanation.
Connector Creations- Welds and Bolts (youtube.com)
Thanks
Rajashri
