Having temporary nodes in the model before running has any effect on the results? Is it recommended to remove all the temporary nodes before running?(temporary nodes created while meshing or any modelling operations)
Hi Aditya,
It has no effect on the run if you run with the temporary nodes in the model. But it is a best practice to delete all the temporary nodes and unused entities before running.
Regards
Prajval
