How to export a geometry mesh from CADFEKO using a LUA script
I'd like to use FEKO to create the mesh of my geometry. Then, through the CADFEKO Scripting API, export the mesh in a custom format. I am familiar with how to do this through POSTFEKO, but I do not want to run the FEKO solver. I would like to simply run the mesher and export the mesh. I need all the X, Y, and Z values of the mesh points, and the connectivity matrix. Can someone help me with this?
Thanks,
Ricardo
Have you tried script recording?
For example, recording the export of a Nastran mesh gives:
-- CADFEKO v2021.2.1-10137 (x64) app = cf.GetApplication() project = app.Project --- Mesh export --- project.Exporter.Mesh.ExportFileFormat = cf.Enums.ExportFileFormatEnum.NASTRAN project.Exporter.Mesh.ExportMeshType = cf.Enums.ExportMeshTypeEnum.SimulationMesh project.Exporter.Mesh.ExportOnlyBoundingFacesEnabled = false project.Exporter.Mesh.ScaleToMetreEnabled = true Union1 = project.Geometry["Union1"] geometryTargets = { Union1 } meshTargets = { } project.Exporter.Mesh:ExportParts("C:/Temp/mesh_Export_nastran.nas",geometryTargets,meshTargets)The Nastran mesh file contents:
$ NASTRAN file exported by CADFEKO version 2021.2.1-10137 (x64) $ $ Filename: C:/Temp/mesh_Export_nastran.nas $ Date: Tue Oct 12 2021 $ $ Number of segments: 0 $ triangles: 33808 $ cuboids: 0 $ tetrahedra: 0 GRID* 1 2.331719118E-04 0.000000000E+00 1 * 1 0.000000000E+00 GRID* 2 2.331719118E-04 2.331719118E-04 2 * 2 0.000000000E+00 GRID* 3 1.888222675E-04 1.319775054E-04 3 * 3-1.368038441E-04 GRID* 4 1.634252528E-04 2.862700521E-04 4 * 4-1.663169480E-04
I tried this approach, but I would have liked to be able to export that same mesh information in a custom '.txt' format. In any case, I appreciate the insight, as I am able to use this approach in my project.
Thanks!
Another option is to export the mesh to the *.out file and use the "check-geometry" mode of the solver which runs very quickly.
Check the box below.
Then check the box "Only check the geomery" below:
When you run Feko, it will only check the geometry but nothing will be solved. The geometry will be written to the ASCII out file:
DATA OF THE METALLIC TRIANGLES no. label x1 in m y1 in m z1 in m edges medium x2 in m y2 in m z2 in m medium x3 in m y3 in m z3 in m nx ny nz area in m*m 1 Cuboid 8.4049E-01 5.0000E-01 1.0000E+00 1 2 3 Free s 1.0000E+00 4.0000E-01 1.0000E+00 Free s 1.0000E+00 6.0000E-01 1.0000E+00 0.0000E+00 0.0000E+00 1.0000E+00 1.5951E-02 2 Cuboid 8.2683E-01 6.9206E-01 1.0000E+00 4 5 6 Free s 1.0000E+00 6.0000E-01 1.0000E+00 Free s 1.0000E+00 8.0000E-01 1.0000E+00 0.0000E+00 0.0000E+00 1.0000E+00 1.7317E-02 3 Cuboid 1.4440E-01 1.2741E-01 1.0000E+00 7 8 9 Free s 1.7399E-01 3.0388E-01 1.0000E+00 Free s 0.0000E+00 2.0000E-01 1.0000E+00
and
DATA OF THE METALLIC EDGES (with MoM) triangle no. points of tr. information on symmetry no. type length/m media KORP KORM POIP POIM yz xz xy status 1 1 1.8827E-01 Free s -1 1 19 2 1 0 0 0 unknown 2 1 1.8827E-01 Free s -1 1 26 3 1 0 0 0 unknown 3 1 2.0000E-01 Free s -1 1 370 1 1 0 0 0 unknown 4 1 1.9612E-01 Free s -1 2 19 3 2 0 0 0 unknown
Data for segments:
DATA OF THE SEGMENTS no. label x1 in m y1 in m z1 in m nodes medium x2 in m y2 in m z2 in m length in m radius in m x3 in m y3 in m z3 in m 1 Line1. 2.0000E+00 0.0000E+00 0.0000E+00 1 Free s 2.0000E+00 2.0000E-01 0.0000E+00 2.0000E-01 1.0000E-03 2.0000E+00 1.0000E-01 0.0000E+00 2 Line1. 2.0000E+00 2.0000E-01 0.0000E+00 -1 2 Free s 2.0000E+00 4.0000E-01 0.0000E+00 2.0000E-01 1.0000E-03 2.0000E+00 3.0000E-01 0.0000E+00
See the Altair_Feko_User_Guide.pdf for more information.
