In order to automate a post treatment for different simulation, I used the GLOBAL_OUTPUT_REQUEST card to generate .disp file. The problem is that there is no space separator between different columns for negative values, it's hard to separate the datas quickly when reading in Excel. Here is an example of displacement in 2 nodes for a given load step:
Is there an option to modify the columns length or the number of digit of each values in order to have a space separator?
Thanks,
