I am working on sloshing motion of water in a tank carried on the vehicle.
I want to modeling the sloshing motion of water with SPH in Radioss. Then I will add the effects caused by the sloshing to the vehicle model in motionsolve.
In short, I want to transfer data between radioss and motionsolve. You said earlier that there is not direct couple between radioss and motionsolve.
What would you recommend so that I can do what I think?
Thank you.
