(Solved) Bulk time history data from HyperStudy for use in HyperGraph
User: "Autumn"
Altair Community Member
Updated by Autumn
Is there a simple method of obtaining all of the time history data from multiple runs from a DOE in HyperStudy so that it can be easily plotted in HyperGraph? I understand it is possible to select multiple time history files in HyperGraph and that you can plot data curves simultaneously that way, but when there are a lot of runs this process becomes tedious as each time history file is in its own sub-folder in its own run folder. Just wondering if it's possible to - or if anyone has found a method of - dealing with a large number of time history files and manipulating/plotting them in HyperGraph without needing to go into each run folder individually while selecting multiple files.
Thanks in advance for your time and help.
