I have completed a DOE in HyperStudy with a large number of runs and am curious about responses that I hadn't originally defined in the 'output response' step of the 'definition' stage. Is it possible to add more responses and extract the data from the runs in order to post-process without re-running every single run again?
Thank you in advance for your time and help.
