how to control the size of a gif video or movie with hyperworks ? I can't find the parameters. I reduced the jpeg quality, the number of frames
Thank you for your help
Regards
Daniel
There is not much you can do to control the storage size "it is what it is", to change the physical dimensions (which will also affect storage size) you can simply resize the graphics area before capture, e.g. below the lower gif is captured with smaller window than the upper gif, resulting in file size of 215KB vs 330KB
Ok , thanks for the advice
