Orientation Name doesn't show up when I assign System Collector to a Property
I'm trying to attach an orientation (coordinate system) to a property that I've created via ID. I'm able to type in the ID number, highlight the appropriate coordinate system/collector, and select/proceed, but as you can see in the image below, the orientation name is not updated accordingly. This has led to errors with my generated input file. Any help is much appreciated - thanks!
1 - 1 of
11
Hi
what is the HyperMesh Version and user profile you are using?
Regards
