🎉Community Raffle - Win $25
Join and Win
Creating Single Lattice Unit Cell for Export from Inspire
User: "Autumn"
Altair Community Member
Updated by Autumn
I am attempting to use the 'Fill' feature under 'Polymesh' in Inspire to create a single (1) lattice unit cell so that I can import the geometry into Hypermesh. I know the height, relative density (and strut radius), and lattice type that I'm looking for, but am having issues with the 'Fill' feature.
I started by creating a cube with the dimensions of the desired unit cell, but when I use 'Fill', and input the desired height, it doesn't appear (no preview), whereas if I reduce the size, it does. I assume this has something to do with the specifications causing the unit cell to be too large to fit the cube, so I'm wondering if you have any suggestions for how to create just one lattice unit cell when I know what I want as its overall cell height, strut radius, and lattice type.
Thanks in advance!
1 - 1 of 11
    User: "Mark McDowell"
    Accepted Answer
    Updated by Mark McDowell
    Hello Mrs. Bernard,
    Please always let us know what version you are using.
    Once you Filled the geometry using Fill
    Use the Convert Tool to "Convert" it to a CAD
    Once you have done this you should be able to select and save selected as stmod, parasolid, STL, Step...
    Any of these formats can be imported into HM
    Mark
