Is there a timeline when ProMan will be able to support propagation modelling at lower THz bands (at least across the 80 - 330 GHz range)?
So far WinProp can be used up to 100 GHz.
Basically at higher frequencies the diffractions will disappear, for the other interaction types the material properties need to be adapted.
So it should be feasible to increase the upper frequency limit in the mid term.
