Hello All,
I am trying to develop a simple shear test simulation, but I want to set the particles as a wall. Does EDEM have this feature?
See the attached image for clarification.
Best
Saeed
Hi Saeed,
You can create 'fixed velocity' particles, it's shown in page 5 of this tutorial:
https://support.altair.com/community?id=kb_article_view&sysparm_article=KB0119679
Potentially you could also create the wall as a meta-particle (which are also shown in the tutorial) or using a lattice factory.
Regards
Stephen
My preffered approach is to use a geometry to create a static particle boundary layer. This makes life much simpler. Please see attached guide on modelling a direct shear test in EDEM along with an example and edempy post-processing tools.
Best regards,
Stefan
