Hi All,
I'm using Hypermesh 2021.2 version with MSC Nastran as a processor. Usually I get an .op2 file as a result file.
As showed in the topic title, the question addresses to finding a way to load an .op2 file and getting frequency values and Modal Partecipation Mass Fractions.
I'm currently able to get from an .op2 file the CBUSH forces (using readvector or readmultivectors), but I'm not able to get frequencies value list and Modal Partecipation Mass Fractions by using the same method.
Is there a different method or a command to use?
Thank you very much
