I am working on a project where there is a pin inside a hole that is pilled.
Everything seems working well, except for the auto contact function.
 As you can see on the photos i posted in this question, in a normal case, on an hole there should be a deformation that cause a detachment of the pin with the hole. In my simulation that doesn't happen.
Even in the base of the component, were there is a simple friction contact, the two parts act as if they were glued.
 Thanks for your attention.
